In Adventure 03: The AI Observatory, you are stationed at Perimeter Alpha, a remote research outpost where the central AI, HubSystem, is behaving strangely. Bandwidth usage is spiking, and nobody knows why.
Your mission? Instrument the AI, trace its thoughts, and solve the mystery.
Beginner: Calibrating the Lens
In this level, you will learn how to bring visibility to a “black box” AI application.
What You’ll Learn:
AI Observability: How to instrument Python LLM apps with OpenLLMetry.
Tracing: How to send traces to an OpenTelemetry Collector.
Root Cause Analysis: How to use Jaeger to inspect prompts, token usage, and model responses to find hidden issues.
The Tech Stack:
Python & Ollama (Local LLM)
OpenTelemetry & OpenLLMetry
Jaeger
Kubernetes (pre-provisioned)
New Verification System: We’ve streamlined the process! You can now verify your solution directly inside your Codespace and generate a Certificate of Completion instantly. No more waiting for CI pipelines!
Hi! is this challenge still valid? I can’t see 30103 in ports tab and also there’s no kubectl, i tried to also get pods with a downloaded binary of kubectl, but still can’t access pods..
